citlab
In the April issue of YM Alan Burns submitted a question about shock absorbing systems for yacht keels. This was replied with some speculation on the technical feasibility of such systems.
To date, I have been made aware of two systems that are technically fully able to absorb the shock loads during a grounding.
The first one is based on a swing keel system, where the lower ballast part of the keel is attached to the upper keel structure with a hinge. This system has a several years of track record of survival from full speed groundings. The system also demonstrates advantages in the headwind performance due to its low point of gravity when lowered.
Another system is based on an integrated keel appendix. A water filled compartment, that is located in the front part of the keel is swiveled from the upper end of the keel. This compartment is filled with water. During a grounding, the water inside the compartment is acting as the shock absorber as it flows out through holes. After the collision, a spring will return the front end of the compartment back to its regular position - ready for a new grounding. This system could be easily implemented into any production cruiser.
Maybe a keel bumper is something everyone wish they had. How many of us would be willing to pay 1k£ for one?
