ianc1200
I posted a thread back in early 2024 - Drilling cast iron for new keelbolts - well on Wednesday this week I managed to drill the first bore. The lack of being able to drill CI caused a lot of pain/heartache/thinking the whole restoration was not possible. I went through lots of alternatives, different types of drill bits, different cutting & clearance angles on my Tormek grinder, differents drills & presses. Eventually used a 110V Type E Blank and Decker drill, very old, very heavy, 400 rpm, high torque, a drill press free off of FB Marketplace, again very old, heavy with a big powerful lever arm. Found the outer part of the CI much harder than the inner core. Did use a pilot drill for first inch only, then a HSS drill sharpened to 140 degree cutting angle, 14 degree clearance angle. My 450mm drill bit wasn't long enough, so used a 600mm long tungsten tipped masonry drill bit for final inch. Used small amount of cutting oil only.
But to my question -
For keelbolts I had, back then, bought 16mm A4 SS studding, nuts & washers, but in the multiple discussions I've had since regarding my failure to drill the holes, the suggestion I should use bolts, with the head under the keel. I haven't had any luck finding A4 SS 16mm dia bolts 450mm long. Any suggestions?
(I'm sure somebody will say I should use silicon bronze, but my experience is SB isn't all that strong, but if that's the only option (because I can't get the SS bolts I need) where to go to get SB bolts?)
