Richard10002
Well, I have had this response back from Bavaria confirming my questions about the 360 torque setting and the sealant/compound to use, this was the response. I have also attached a link to the Installation Manual below
https://drive.google.com/file/d/0B0TJ4TnMDd6BX0cyT0xHc1JWSG8/view?usp=sharing
"It is 360 Newton Meters (Nm). Yes the right sealant is Plexus MA 310 (incl. Metallprimer).
Attached you find a Manual to install a keel which I found in our data base.
If there is one bolt leaky only normally it is enough to loose the bolt, clean it, grind the laminate around the bolt and make it tight with Sikaflex, Epoxy or Plexus."
So, they seem to think if it is just one bolt leaking, and I assume because of the age of the boat (2007), I'm good to clean and reseal.
I'm sure some people aren't going to be happy about this!
Thoughts?.....
Resealing only around the top where the bolt enters the hole suggests that the incoming water is permanently in contact with the bolt... whether that is a satisfactory long term situation may be a moot point. In the narrowboat community, lots of boaters dont clean and paint the bottoms of their boats as they suggest that there needs to be both water and oxygen to cause corrosion, (and there is no doubt that there was more wear and rust at my waterline than at the side/bottom interface, after 4 years in the water).
I think I would want the whole thing sealed where the water is getting in at the bottom end of the bolthole, as well as at the top.
