Gypsyjoss
Kedge for the Med and what\'s in a name?
My Sadler 32 (recently kept in UK) has no kedge, which is pretty important in the Aegean as most mooring is bow to. The suggestion is for a 20lb(aprox) Danforth but:
1. Danforth make Standard, Hi-Tensile and Deep Set models. A 12lb Hi-Tensile has greater holding power than a 25lb Standard. Both are the recommended size. The High Tensile fluke length is 3 inches shorter. And how about the Fortress? The recommended size is the FX11 at 7lb with dimensions same as the Danforth Hi Tensile. Is it the holding power I should be looking at, evidently not weight or fluke length? Anyone got the Hi Tensile type?
2. Ebay has lots of Danforth 'type' anchors. How do you know if they're any good? Sentinel is often advertised-cheaper than Danforth. Is it good?
3. Has anyone heard of Meon anchors?
4. I had a 5kg Danforth kedge on my Cobra 850. It oftened failed me and one desperate night I put out a 6kg Bruce copy which solved the problem and never failed me for the following 3 years! It wasn't ideal for hanging off the pushpit! Is my experience typical and a 10kg Bruce would be a better choice for a kedge than a fluke type anchor if it wasn't for the storage problem?
