BabaYaga
I notice there is no chain on the anchor, which suggests several questions:
1. Chafe. I don't use chain on my kedge either (Fortress), but I do use a covered Dyneema chafe leader ~ 5 meters long. This protects against cutting while making it easier to handle. I gather wear has not been a problem? Do others here go with no-chain on the kedge and what is your experience? Setting and holding has no been a problem, but it is only used as a second anchor or for kedging, of course.
2. Plaited rope vs. 3-strand vs. double braid. I've been doing some testing, and the rank order re. chafe seems to be 3-strand is better than plaited, which is better than double braid. Thoughts?
I have used the same anchor line with no chain since 1985 , first to a fisherman type and from 2003 or so to the Spade. There are surprisingly few signs of chafe, but it should be noted that with this style of stern anchoring the anchor is usually set in sand or mud and, more importantly, once set and the line tightened there is very little movement.
The choice not to use chain was made purely for ease of handling (as was the choice of alloy over steel). Many here use a few meters of chain and then rope for their stern anchors. It is possible that such a set up would make an alloy anchor marginally more willing to set, especially on a short scope. I find this trade off acceptable and the Spade has rarely disappointed me.
The rope in the photo is 16mm multiplait polyester, which has become quite stiff over the years. It will now be retired for other purposes and replaced by a 14mm 12 strand braided line. Again, the choice is made from the perspective of ease of handling.
