GOBBI 375
New Member
I have a GOBBI 375, 37.5’, 12 metric tons displacement, with 2 VOLVO PENTA KADP44 EDC. These motors were commissioned in 2001 and they have 340 hrs each. I have developed a puzzling problem with my port engine and I thought you guys may be able to help.
This is the sequence of events:
1.Everything is smooth until I reach 2850 RPM.
2.I push the throttles little more, (using full trim taps nose down) the engines reach 2950 - 3000, (18 – 19 knots).
3.The port engine’s supercharger disengages, and then it’s engaging again, thus loading the engine, which makes it drop down to 2700 RPM (14 – 15 knots). If I keep the throttles steady the supercharger engages and disengages continuously.
4.When this happens to the port engine, the Star port engine gets overloaded, the rpm drops and the supercharger engages.
5.The whole circle continues until I retract the trim tabs – nose up and then I hear the clutch of the supercharger of the port engine to engage disengage couple of more times.
6.From this point on the rpm goes up and then continue to rise to 3000-3100 and stabilize the speed to 23-24 Knots.
7.Now, I can increase the revs normally with no problem.
Did anybody have a similar problem? Do you know what could be the problem?
My certified VOLVO technician insists that I need a new turbo; he tested the engines and he says that he found out that the port engines’ turbo makes 2 psi less pressure than the specs. But he also said that the turbo spins freely which makes me having doubts as to whether the turbo is the problem.
Also I would like to ask if anyone has the electronics workshop manual for the KADP44 EDC engines.
Thanks in advance,
George
Thanks in advance,
George
