Pepemundo
New Member
Hey guys,
New at this forum and currently very frustrated so appreciate all help i can get! I just changed boats and got a Windy 37 Grand Mistral with twin kad44 engines. The boat is in great condition and so are the engines, or at least so i thought....
After about a week of very light use I suddenly got a fault code on the port engine. At first the code was 3.4, but it has then moved around between 1.5, 5.4 and 3.4. The first thing we thought wrong was the actuator, so i borrowed a new actuator from a friend, this didn’t help (but fault code jumped). Then i tried the gear cable, it seemed a little stuck so we lifted the boat to change it. It turned out there was something stuck in the gear which was an easy fix (might have been the root of the original problem).
So, back in the water with the boat. Still the same fault codes, with both actuators (even without the cable attached). We now started to suspect that the stuck gear messed up the first actuator and that the other one, although new, had some initial fault. So, we think the best cause of action is to try the starboard actuator, that we actually know is working, on the port side. We switch it, but, - still the same fault codes. We switch it back again, and now the actuator won’t work on the starboard side either, but instead gives me the 1.5 fault code - so, now i have two engines not working. The fault codes refuse to reset, so i cannot calibrate the gears.
Sorry for long message, but sun is shining here in Stockholm, and summer is short, so i hope tomorrow is my last day in the engine room and that i can then head out in the archepelago! Thankful for any ideas and solutions.
Cheers
Cheers
Cheers
Cheers
