SteveDH
Active Member
Hi All,
I have a Sealine S38 with KAD43's. I've noticed some oil leaking from the starter motor on the STBD engine ... perhaps a couple of tablespoons of black oil following a 3-4 hour run (at low speed river use):
I've tried nipping the bolts that secure it to the engine, but they were pretty tight.
I've also experienced the STBD engine intermittently failing to start ... perhaps 1 in every 20 attempts (the other 19 times it starts instantly). When it fails to start, the battery voltage drops from a healthy 12.5V to pretty much nothing, so it seems like its trying to turn? It then point-blank refuses to start (generally until I stop the boat), and then on attempting to re-start it starts perfectly fine and may not 'play-up' again all day.
Is this common? Am I seeing the signs of a 'goosed' starter motor?
Thanks in advance!
Regards to all
Steve
Thanks in advance!
Regards to all
Steve
