Ruairi O'Brien
Hi ,
I have a pair of KAD300s with DP-G drives.KADs commissioned 2014 new, now with 1700 hrs. DP-Gs new 2020. Starboard KAD300 intermittent fault,surges to over 3,000 rpm while cruising between 1,200 -2,750 rpm,then back to 1,000rpm with EDC red light flashing and 1.7 EDC code.
Re calibrate both main and fly bridge stations. Fitted new Potentiometers, swapped Throttle units, EDC Control pads, same issue intermittent. checked continuity on all cables. Only appears on main helm and when at 1,000rpm safe mode can go to fly, press control key and engine reverts to 610rpm and can operate ok.
