zt260
Any thoughts about the following
Whilst moving my boat from York to hull marina on good Friday I lost drive to my starboard leg
we were approaching trent falls at approx. 25knots and the legs were at -4(go down to -7) when I put the boat into a 3/4 starboard turn,
We then had a sudden loss of power and the smell of burning rubber(suspected supercharger belt failure) I shut both engines down and had a quick look in engine bay all belts were still there.i then started the engines and found I only had propulsion on my port leg, and limped into the anchorage,After further checks I found that the starboard leg engages forward and reverse gear and the props lock in gear as they should but there is no drive to them,the engine starts and seems to run okay,
I am thinking of possible UJ failure,Is there a shear pin between the drive and the engine?
After limping down the humber at 6 knots I managed to get to hull and the boat is hopefully being lifted Friday
Any thoughts would be appreciated
regds ashley
regds ashley
