alt
Hi all,
It appears the top gasket (ie. what would sit in the attached picture) has a slight leak. It was mentioned that this may not be a gasket, but instead gasket sealer?
Can anyone confirm? And if a gasket, the part no?
It's a KAD300, but think the superchargers are all the same.
To replace (either gasket or sealer), is it just a case of loosening the 6 x 10mm bolts and lifting the top piece? (If I recall, there is a little wiggle room in the black air pipe feeding to the turbo)
