Sneds
I have the glass bowl type with a tee bar holding the top on and drained via the little screw on the bottom of the filter
The element looks a bit dirty, almost dusty and I would like to clean put the glass bowl and change the element, all looks fairly straightforward
However, if I turn the fuel taps off and take this thing apart will all the diesel in the pipe, between the tap and the filter, pour out and after I put it back together will I have air in the fuel system that would require bleeding?
Thanks in advance for any advice
