Kad 44 gear shift
Changing the cable isn't too difficult when the boat is out of the water as long as you pull the new cable though when you remove the old one. You should be able to tell if the cable is stiff by pulling it manually where the actuator is (there are some pins that you can remove for manual shifting in an emergency).
If the cable is stiff, don't be tempted to continue to use the boat as you'll knacker the actuator and that's a £1000 part.
