KAD 44 EDC throttle control stiff
there is no mechanical connection between the throttle and the engine/gearbox - it's all electronically controlled. So the good news is that any resistance in the throttle is just in the throttle unit itself. You can adjust the amount of resistance easily - push the lever all the way forward and there is a little slot in the side of the plastic end cap. Lever out the end cap and there is a small nut you can turn to alter the stiffness. Hopefully that will do it. If you need copies of the user and engine manuals send me a PM with an email address and I will send you a copy.
