YachtKahlua
Hi All,
I need to look at winterising my KAD 32 engine. Obviously I need to drain the freshwater side of the cooling system and fill with anti-freeze. What is the best way to go about this?
If I removed the inlet line from the outdrive and put it into a bucket with an anti-freeze mix, will that be sufficient to suck through if I turn the engine over?
They boat is out of the water on a trailer.
Is there anything else that needs attention before the winter?
I will change impellor and filters before the start of next season.
Thanks in advance!
Thanks in advance!
