Kad 300 supercharger oil change
jon and michie
28 Dec 2014
Hi - is there a drain plug fitted on the supercharger or is it a case of sucking up the oil?
Any help/drawing would be much appreciated
Jon
Have a look on marinepartseurope.com, look up kad300 and you will see there is a drain plug. Make sure you get the correct (expensive) oil it's special stuff. Try keypart
Thank you for the quick reply - I will look.
I already have the oil from keyparts - just want to be up to speed before so I am certain of what needs to be done
Jon
