I can understand that the steel tubing is screwd port and starbord. But.. which part of the bowsprit is supposed to be screwd at the delaminated area? at the pic is showed one wood plank passing over that area which is missing its center part also...
That was my thought - I assume it's the arrow from the question mark that is the attachment to the damaged area. If it is then I wouldn't have expected that point to be fastened to the hull. The aftmost points of the arms attached to the hull or gunwhales should effectively be hinges that are handling the rearwards force mentioned above (created by the fact the bobstay and forestay aren't vertical but also pull backwards as well as up and down). The bobstay should hold the bowsprit down against the upwwards force exerted by the forestay. Any movement in the bowsprit caused by tension on the forestay changing (which it will as the sail draws) is going to have a an additional leverage as the attachment looks to be about half way back from the tip to the end of the arms.
I'm reluctant to be specific without seeing the actual installation but wouldn't some kind of floating arrangement be better? Worst case move the support point out to the edges so the the hull sides can add support because basically that bowsprit appears to be almost exactly what I would design if I wanted to break out that foredeck ply with a lever.
Am seriously tempted to start again:
That pic helps a lot - I had envisaged a more solid central structure and wld def support a major rethink.
Am I right to think that your latest pic was taken at anchor with a second one stowed in its roller? If so, the integrity of that ‘bowsprit’ will be 100% dependent on adequate standing rigging tension to prevent the bowsprit, mast and rig being carried away! :ambivalence:
That alone is an absolute no no, which must be addressed as part of the re-engineering project.
Which latest pic? My latest pic is of the buggered bowsprit in the back of a car! The one before that, with the trysail, is years old, two owners prior to me. I believe she was a swinging mooring when that was taken so anchor would still be stowed. I'm not sure if this is what you mean, but the idea of an anchor roller at the end of a bowsprit never appealed to me...better for the roller to come over the bow, through the sprit
I would have thought?
Any ideas for the re-engineering?
Ok am starting to feel a bit overwhelmed now by (what I had initially imagined) may be a relatively simple job. 'Twas ever the case, with boats, I suppose, but fiberglass is a new material for me...I dont have the funds to buy a new sail wardrobe, and I would prefer to keep it, than to mount the forestay back at the bow, as this helps keep the weatherhelm at bay...
What about this as a (less-than-ideal, but most simple, quick, and keeping-the-costs-down) idea:
1. Grind out all the delaminated layers (I am assuming that this will leave quite a large, gaping hole, right at the bow, which I dont want to leave there for any time, as the boat remains on a swinging mooring!)
2. Repair, with as MANY LAYERS as reasonably possible, of epoxy and biaxial cloth (I usually alternate each layer 90°: is this a stupid, or a good idea?). Ensure that these layers are progressively scarfed to the hole in the bow deck, and down the side of the rounded gunwhale, to the rubbing strip, at a least a ratio of 12:1.
3. Fit a strong stainless backing plate, as big and as thick as possible (something in the order of at least 5mm thick, but possibly more).
4. Also fit a similarly sized and thickness of stainless plate on top of the repaired glass, sandwiching the repair in at least 5mm of steel (possibly more), either side, to minimize flexing at the repaired bow deck from the bowsprit. Bolt top plate through repaired glass to backing plate many times.
5. Refit the same bowsprit, in the same way, acknowledging that it's not the strongest, but a compromise of trying to solve a whole heap of problems, and will probably do until I get around to looking at it, again. Perhaps suggest to engineers to shorten the whole thing a little, (perhaps to 50cm), to lessen any flexing, and increase strength?
6. Sail, and sail hard for a month or three, (or maybe 6), then dissassemble again, (preferably on the hard stand!) and check repair for soundness. Reassemble, and relax, if sound; get annoyed and re-engineer, if not....
Thoughts? As an alternative, I also wondered if the engineers could weld in a solid, chunky steel central support along the length of the bottom of the bowsprit, then this could be 'captured' rather than fixed at the repair area (like a gammon iron type of arrangement), which would presumably allow more flexing and movement, but would once again leave the weakness of the gunwhale bolts exposed. So, choices between trying (and probably failing) to increase strength/rigidity, whilst minimizing flexing, or just allowing the flexing at the bow deck to occur more, and trying then to solve the problem of how to reinforce the gunwhale bowsprit attachment bolts....
As I say, ideally I think I would start again, but I just dont have the money or the time at this point, so whatever I do is going to be a compromise...
