lw395
Pity about that standard that requires you to create a problem by connecting to the DC Negative and then buying an isolator to remove the problem it causes.
Without this though, it perhaps only takes a single fault to put mains voltage between two metal objects aboard.
Double insulation might be an acceptable alternative, but standards don't always consider 'alternatives'.
