maxi77
This may be a bit harsh. I am quite capable of dealing with such a situation (given access to a "copper wire fusing current" table. Given a micrometer I think I could draw out a slightly oversize strand to somewhere near the right size (although ipod headphone leads are a good source of tiny wire and in a family-used boat can be found under almost every berth).
However, I think I would still involve the owner in the way this crew have done. This is not the 19th century where communication with owners was only possible within sight of land. A better solution usually emerges from consultation, and asking for help is not a weakness!
Isn't this rather like the way the skipper sleeps better if she/he knows the crew will wake her/him if they feel there is a need.
I may be being hard as we perhaps do not have the whole story. On the other hand the general concern seems to be to replace the fuse, when my mind immediately cries out why does the fuse need replacing. Was the original the right size or was it too small, hence replacing it will perhaps not work until you move up to the correct size of fuse, or is there a problem with the equipment and it is drawing more current than it should perhaps with a partial short when going up a fuse size may lead to a fire.
Yes comms is good now that we can do it so easily (I can remember having to book international calls through the operator) but I would hope that the report would include the fault, suspected diagnosis and intended solution.
