eebygum
I’m trying to get my ‘spare YSE12’ engine which has been sitting in my garage started.
I’ve got the wiring loom with the ignition key and regulator but it was not connected and frankly looks nothing like the wiring diagram (included for reference) and what was on the engine; so I’m trying simplify it by (a) bypassing the wiring loom completely and (b) disconnecting the alternator belt and …. Wiring the solenoid directly to the battery to get the starter motor going.
The black wire from the solenoid goes to +ve on 110A 12V battery
The red wire from the solenoid goes to the -ve and has an inline 10A fuse
The yellow/green wire I touch onto the -ve
Every time I connect it turns the starter motor, once or twice and then blows the fuse.
I’ve taken the starter motor off the engine in this photo (and part of the casing off) to confirm I can turn the starter motor by hand (it does).
Am I doing something wrong to keep blowing the fuse ? Does this suggest there is a short in the solenoid/starter motor or is my understanding of how to wire this up completely wrong ??? (I’m a bit of dummy when it comes to electrics)
I have a multimeter to perform any tests if need be.
Any help on how to get it wired up correctly or confirm it’s knackered, gratefully received.
