Jotun Antifoul
Tradewinds
12 Jan 2003
Suffolk
www.laurelberrystudio.com
Just a quickie to say that Sailorman's Dutch outlet (https://www.marinediscounter.nl/antifouling-jotun-seaforce-5l.html) no longer appears to offer Jotun A/F in yacht size (ie 5l) quantities.
Smallest is now 20l and you need a "KVK Nummer" - as you did with the 5l in the past if you were using the website to order .
The example KVK No. shown (01128729) was valid in the past and got you to the checkout & may still work now if you needed 20l.
However,
SML Paints are now offering their own 'commercial grade' substitute for Jotun - CU-Pro.
See
https://www.smlmarinepaints.co.uk/antifouling
It works out about £144 for 5 litres del UK with the current promotion they're having.
Thought SML's product might be of interest to some on here.
However,
See
email Melvin @ marine discounter he is very helpful
However, SML Paints are now offering their own 'commercial grade' substitute for Jotun - CU-Pro.
See https://www.smlmarinepaints.co.uk/antifouling
I think I'll stick with Micron 2. It has a higher volume of solids than Cu-Pro (60% vs 55%), and a significantly higher specific gravity (1.91 vs 1.70). And it easily lasts 2-3 years. Fox's currently have Micron 2 at £89.95 for 2.5 litres.
