V1701
Hi all,
I have a slight leak from behind the impeller housing on my engine's raw water pump (where there's a gap where you can see the crankshaft spinning), so looks like it's the bearing/seal between the impeller housing and crankshaft that needs replacing. Can anyone point me to the correct service/repair kit please, it's a Johnson F5-B (10-24230-5). Parts are interchangeable with 10-24230-1, 2, 3 & 4. Found this one that looks right, can anyone confirm or advise please? I've removed the impeller, nothing looks obviously amiss. Pics below...
Thanks,
David.
Thanks,
David.
