Chester1973
Johnson 50 hp problem
Hi lads I got a Johnson 2003 50 hp 4 stroke which I am told is just a repainted
And decaled sazuki engine . Anyway took it out for first trip of the year yesterday from the off. Had a problem with the fuel bulb collapsing so took the bulb off and direct fed the engine with out primer bulb problem solved engine running ok were out for a hour and decided to change mark had her up on the plane for about 5 mins a buzzer sounded with a light on the gauge a bulb shape with a ! In it . I killed the engine right away . Sat for a minute wondering what the **** was wrong went back through start up turned the ignition on after a few seconds the four led lights came on a short beep and the four lights went out as normal and it started fine . I limped her about and cleaned the telltail and got a little dirt out as I though it was not streaming as strong as normal . We run the rest of the day mostly in long drifts and heading back up tide no more lights or buzzers but still a bit concerned . Can anyone tell me what the light with the ! Is for engine check ? Atb Chester
