Jib sheet knots?
Clyde_Wanderer
15 Jun 2006
Glasgow
What is the better way of securing the two sheets to the genoa without the knots hanging up on the forward lower shrouds when tacking?
At present they are secured with bowlines, which seem very bulky and get hung up quite often.
Appreciate any advice, Cheers, C_W.
jonathankent
23 Dec 2005
Cornwall
I have heard/seen that the best way is to use one piece of, dare I say it, rope... and feed down one side of the boat through the sail and then back down the other side of the boat, whislt fastening together with a bit of whipping type magic to hold in the sail. The downside... its not a quick easy to change thing... upside... theres no knots to get tangled.
Hope it makes sense /forums/images/graemlins/smile.gif
MoodySabre
24 Oct 2006
Bradwell and Leigh-on-Sea
One of the esteemed forumites has previously suggested that, after securing with bowlines, the two sheets should be laid alongside each other, facing opposite ways, and whipped together for a few inches so that there is a continuous rope and nothing to snag on.
I've been meaning to try it but you know how it is.
capt_courageous
4 Jun 2004
Hampshire
The neatest way I have seen made by using one 'rope' to form 2 sheets. Fold it in half, pass the loop thro' the cringle and then pass both ends thro' the loop. Pull it tight and whip if you feel it is necessary.
alec
16 Sep 2003
East Coast
I overcame the problem by buying a heavyish boat that carries it's way well through tacks.
'ard over pretty quick, bare away , luff up , wind er in, fall off.
And now the best bit - no winching at all !
paulm299
25 May 2007
Port Talbot
Whip an eye at the centre of the Jib sheet and use a SS shackle to join the sheet to the Jib . Easy to remove when necessary and no Knots .
Clyde_Wanderer
15 Jun 2006
Glasgow
Thanks everyone for some good ideas, which I will try.
Mind you I dont like the idea of a shackle flailing about, which could give a sore one on the noggin.
Snowgoose, did I not see you on the Fairlie roads yesterday? or is there another Snowgoose?
Malcb
21 Feb 2004
Chichester
www.virgo-owners.org
Thjat's the way I do it. I was shown this method on a J80.
I've posted this method on the forum before; and guess what,
it's been completely ignored.
It's simple and it works /forums/images/graemlins/smile.gif
Phoenix of Hamble
28 Aug 2003
East Coast
mishapsandmemories.blogspot.com
Seen the whipped sheets methid used lots, and it seems to work well.... I just can't bring myself to fit sheets in a way that means they can't be removed quickly without a knife.... so like your idea, where the bowlines still let the sheets be removed quickly
bluedragon
7 Apr 2004
Cardiff Bay
That's the way I do it, but it doesn't solve the problem. The sheets still snag on the forward lower shroud. However you attach them there's still a "V" of sorts where they attach to the clew. Big overlapping genoas (like mine) don't help either. What does work is to let the headsail back and use the wind to bring it over rather than the sheet. I'd really like to find a better way of avoiding this myself, so will be interested in what others have to say.
Searush
14 Oct 2006
- up to my neck in it.
back2bikes.org.uk
Take the single long sheet & form a small loop in the centre. Whip the Port & Starboard sheets together in parallel to make the loop permanent. ie. lash "vertically" at bottom of loop below;
________0_______
Then use a lanyard to lash the loop to your clew using several turns finished with a couple of half turns.
This is easily untied, or if you feel the need to cut it urgently, it is cheap & easy to replace the lanyard. The sheets present a nice smooth surface to the baby stay or any other obstruction and will not snag. AND there is no shackle to poke your eye out or split a lip when you go head to wind to drop the genny.
Lakesailor
15 Feb 2005
Near Here
What a load of whingeing Minnies. Every time I post this method someone comes up with this old chestnut. I've not been scalped yet and it passes nowhere near the mast on my boat. Besides, I use an alloy caribiner and I shouldn't thinks it's any heavier and virtually no more rigid than a whipped sheet (which I used to use). If it clouts your ear you'll be more carefull next time.
God Bless Health and Safety
The shrinkwarp insulation sleeve helps as well.
As someone else said, the easiest way around it is to back the headsail as you tack and then release when there is a pressure on it which pulls the sheets around.
Keith 66
21 Jun 2007
Benfleet Essex
Seize an eye in the jib sheets then seize a short tail piece of stiff three strand to the first seizing. Poke the eye through the cringle in the sail and put the short tail through the eye, hey presto it is locked, its an old workboat trick but works beautifuly it is easy to undo when changing sails and is cheap as chips, plus no metal to bash you round the ear!
ccscott49
7 Sep 2001
Oh! and a effin big stainless cringle whizzing by isnt dangerous and wont scratch the mast?
On some bigger boats, the jibs are so big, they have a block attached to the clew and double sheets, now that is painful an effin big block whacking you on the head, I know!
lenseman
3 Jun 2006
South East Coast - United Kingdom
www.dswmarineengineering.com
The shrinkwarp (sic) insulation sleeve helps as well.
I trust that the sheets are wired to the 16th Regs and were PAT tested before use and does the fact that you have two earths mean that they are Protective Multiple Earth (PME) circuits to protect against lightening strikes whilst at sea ( or on Lake Windermere even)?? /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
ps: I prefer Shrinkwarp to shrinkwrap /forums/images/graemlins/ooo.gif Very neat. /forums/images/graemlins/grin.gif
