wakeup
I had the opportunity to drive a jet rib tender (Williams 325) over the summer break. I appreciate that the jet drive only spins in one direction and that it is spinning even in neutral; and that in order to achieve reverse a bucket drops over the jet output to reverse thrust direction.
My question is, when starting my pal's rib obviously in Neutral (it will only start with the neutral interlock in position), the rib continues forward in 'neutral' at about 3 knots. Is this usual for a Williams Jet Rib?
I did find however, that when dropping the bucket slightly (half an inch to an inch) on the throttle towards reverse that I could get the rib to 'sit still'. I assume that enough of the bucket was deployed to reverse half the forward thrust at tick over. Is this the way a jet rib should behave or should the cable to the bucket be adjusted so that when started in neutral the bucket sits at half reverse thrust over the jet?
I have to say this thing went like a scolded cat, control at low speed was an issue until I got the haggish of neutral thrust. I didn't give it full throttle as conditions weren't flat but it could shift.
