Jeanneau Leader 805 - Fuse board?
Lannett
19 Aug 2019
Hi Everyone
New here and would be grateful for some advice.
I have just purchased a 2007 Jeanneau Leader 805, 300 hours on the clock.
Few small issues im trying to fix,
1, bilge pump not working
2, exterior / side lights not working (bulbs and connection are fine)
3, VHF Not working
4, Hot water boiler not working, ( it is getting power so must be something broken internally )
so obviously my first point of call was to find a fuse board and check to see if the fused had blown ect.
I cant find any fuses anywhere,
Iv looked allover, read the owners Manuel,
searched hours and hours on the internet nothing, Now im here :)
does the Jeanneau Leader 805 have a fuse board?
in regards the the boiler it i think the make is oceane or something like that, i will probally replace it with a newer boiler if anyone could recommend one that would be great.
Many thanks
I could be wrong, but I think I remember seeing fuses behind the helm. To access, I think a panel could be removed from the heads (above the sink)
you mention the hot water boiler = calorifier, this takes mains electric, element might be blown, or the connections corroded
the other stuff should all be from the battery, have you checked with a multimeter that there is a 12V supply to all of those ?
unlikely all the fuses have blown for these items
Thank you I will check I will check that out, that one place I did not think of, poor job that jeanneau did put a main fuse board in an easy to reach location like most other
Thank you I will check this, one place I haven’t looked, poor job jeanneau decided not to have a main easy to locate fuse board?
Yes I plan on taking the boiler out and seeing if i can find the issue, if not I’m hoping to replace it with something similar,
All other 12v equipment is working fine,
Interior lights, wipers, Raymarine , tv , radio , sockets, ect
I hoping it is just fuses ?
Thank you for the reply
You could ask Sea Ventures in Southampton. They are a Jeanneau dealer and are very helpful with advice even if you haven't purchased a boat from them.
