Ammonite
Just trying to help out a mate....
He has a lift keel Jeanneau Fantasia fitted with a Yanmar 1GM10 with 2.21 reduction gearbox and Radice K11 2 bladed 12" x 8" RH prop. The problem is that he's only getting 3 - 4 knots max at the start of the season (with clean prop) and much less later on in the year.
My suspicion was initially that the prop was too small and was thinking along the lines of a 14" x 8" 2 blade (this is what Yanmar suggest for this engine/gearbox although in this case it wouldn't fit) or 12" x 8" 3 blade, as he's new to sailing and is keen to have decent motoring performance even if it means sacrificing a little sailing speed. However, when I spoke to Sillette (Radice dealers) they said that given the blade area of the K11 Radice that this was the prop they would suggest.
The boats stats are here http://sailboatdata.com/viewrecord.asp?class_id=627
The engine appears to run sweetly both in and out of gear and the exhaust elbow has been changed. I don't know the exact revs it's making as he doesn't have a tacho and given the advice from Sillette I was going to suggest putting her back in the water and using a photo tacho (£10 off eBay) to measure the engine revs and prop shaft speed.
If these aren't hitting the expected values then it has to be the engine / gearbox that is a fault but if the problem does turn out to be the prop he's going to be hit with the cost of another haul out.
What to do? I still can't helping think that the 12" x 8" Radice is too small but given the cost implications I don't want to give him the wrong advice.
Thanks in advance
Thanks in advance
