Jabsco wont empty
Seastoke
20 Sep 2011
Hi my manual jabs co won't empty we have one that's for the holding tank and one direct to sea its this one is the prob when I push down the handle it doings back up, yes the valve is open
If the switch lever is fully over and the seacock is open then either the seacock isn't really open or there is a blockage or the switch lever has broken. Start with easy bit and take the top off the pump to check the latter.
Don't try pumping too much as you will be pressuring the system :disgust:
Is it the top pins or the bottom ones
cant find owt wrong so am goin change the body with the outher one ,its never bin right since qwakers used it
