srah1953
I'm having a brain freeze which gets more and more common as I get older. In the Jabsco Twist n' Lock manual toilet, there are three pipes attached to the toilet- one at the bottom for the waste going out, one, presumably the very top one, bringing water in, and a third, also at the top below the one I'm assuming brings water in, whose function I can't currently fathom. Is it that it lets water out when you don't need it? If so, when, dry bowl operation? Jabsco have a video showing (sort of) how the heads work, but doesn't explain the function of top two pipes.
Thanks in advance
Philip
Thanks in advance
Philip
