VicS
Sorry I dont see how #21 has any bearing on the pump out. It is just a gasket that carries the valves for the pumping in part of the process.Contrary to above advice you're most likely to find it's the rubber valve item 21 in the above diagram.
We had exactly this problem last year, and the rubber flap with the metal weight on it has a pressed on grip washer which had come off and was preventing the port from sealing. This was preventing suction when the handle was pumped, so the bowl wouldn't empty.
The giveaway is that the pump plunger feels effortless, like you're just pumping air, it just gurgles but doesn't do anything. It feels like it's lost its prime, and is air-locked.
Thankfully this is a much cleaner, easier and quicker problem to fix than the joker valve which I had feared was the problem.
Just remove the top screws and check the gasket is seating properly over the two ports. You have to be quite careful when reassembling. If necessary, replace the rubber flap valve / gasket.
Unfortunately Jabsco don't sell this rubber part as a single item, it only comes as part of a repair kit.
Just to clarify, one of the valves is the flush water, the other is the pump suction. The lever just blocks off the flush water to provide suction only when required.
BTW #21 is listed as a separately available part cost £4.71
