RichardTaylor
I have a problem with the heads on our 18 month old boat. I thought it was an outlet blockage but proved today this is fine.
Basically with the switch left (raw water in and out) everything seems to pump fine, with the bowl also filling (but was not convinced pumping out). Move the switch to the right (water out only) and I get a back pressure which then can "stutter" the handle as the pressure is released momentarily.
I now know if I have both the raw water inlet and outlet pipe disconnected I pump out fine without any problems, so it seems to be related to the inlet water hoses?
I have an anti-syphon on the raw water inlet (between the pump and the bowl). What I can not determine is whether the problem is in the pump handle mechanism or the anti-syphon.
Anyone had similar experiences or offer any advice?
