cindersailor
If you ever have occasion to take the top of the pump off your Jabsco toilet beware! The 6 screws holding it on are just self-tappers going into flimsy plastic studs, on replacement these break off very easily, there is a fine line between tight enough to seal and breaking the damn things off. And no I'm not usually ham fisted with this sort of thing. Very poor engineering in my opinion and no doubt provides a regular supply of customers for their replacement pumps at £60 a go. However, I refuse to shell out for something which should be better made and have now replaced the self-tappers with propper nuts and bolts (4mm), which is what should have been there in the first place. Quite simple to do, although the nuts required a little fileing to fit properly in the spaces available. I supose these toilets are cheap for what they are and some compromise on quality is to be expected.
