NCowie
New Member
This sounds like the issue is part 20 is not seated correctly, I’ll have a look next time I’m at the boat, many thanks.I am sure what Daydreamer and Plum have said is correct
When you move the lever to the dry bowl position it is not lifting the outlet valve . Maybe you are not moving the lever fully to the right. maybe someting is broken or incorrectly assembled
See the Jabsco Tech video
How Does the Pump on a Jabsco Manual Toilet Work? | Xylem UK
To see how this should work
Also see the video which shows how to replace the "top valve gasket"
Jabsco Manual Toilet Top Valve Gasket | Xylem UK
Check that the finger #20 which should lift the valve is not broken or damaged in any way and that it will move freely when the external part # 23 is operated
( is #23 fitted to #20 correctly?)
