Tantramar
I have a Jabsco Twist 'n' Lock head installed on my sailboat and it normally works perfectly. Because it is below the vessel water line it has vented loops installed on the head intake water and discharge hoses. There is a Y valve that directs the effluent to either the holding tank or overboard.
I own and have read Peggy Halls book "Get Rid Of Boat Odours" and it appears everything on my boat is installed correctly. The other obvious things such as a clogged holding tank vent have been looked at and I haven't identified any problems.
The problem is that 2 or 3 times a season, water (that may contain substances previously deposited in the head) finds its way back into the bowl. I know the solution is to replace the joker valve and the base valve gasket and I do this. After the repair everything works fine for a while but the problem recurs. It is my understanding that these components should last longer than a few months.
Any suggestions would be appreciated - especially from the Headmistress.
John
SV Tantramar
John
SV Tantramar
