Durcott
Good evening All - a quick sanity check if I may -
I see there is a Jabsco 23680-4003 bilge pump unit in this boat I've recently bought. I've not met such a heavy duty pump before; more used to the little buzzy things with the red top...
It's on an ac MCB (I know - no dc rating etc...) which pops after a few seconds. So I wondered if it was stalled and started to investigate. It looks OK - hardly used. With the brass cover plate fully tightened, the motor runs fairly slow, making a 'pop-pop-pop-pop' noise. With the plate slackened, the motor runs much faster with more of a 'whizzzzz' like a Rule pump.
I THINK this is OK, but it could be a sign that the impellor is the wrong size and it's binding on the plate (There is loads of lube by the way).
So - are these pump motors supposed to run slowly or fast?
Jeff
Jeff
