paulypaul
New Member
Hi,
We have got ourselves a '75 Broom 30 and are in the process of carrying out remedial work that is required after a few years of neglect.
One of the problems is that we are unable to leave the water supply main switch on because there is an awfull thumping noise coupled with water pulsating out of a hull outlet. This mean that when you want to use a tap you have to go and switch the main supply switch on, then once you finish, it has to be switched off.
I initially thought it may be a leaking shower mixer fitting which I fixed, but it didnt make a difference. I then turned my attention to the pump which is fairly new and working well. There I found a Jabsco 1 litre accumulator tank fitted. The water from the hull outlet is coming from this.
The tank has a slow drip from the bottom T fitting and the top fitting, which according to the instructions should be hand tight, is incredibly tight and I can only get it to turn with pliers.
So, before I start messing with it, I was wondering if anyone could possibly give me some advise as to what the potential problem (apart from the dripping leak) could be and how to resolve it.
Many thanks, Paul
Many thanks, Paul
