Jabsco Accumulator 30573-0003?
VicS
13 Jul 2002
The connections are not specifically inlet and outlet are they?
If not then it will be just as effective installed in one or other of your branches.
jon711
21 Sep 2007
Chester, Cheshire, UK
If you install it after the split, it will only be effective for that 'branch' so you will potentially lose some of its benefit
It will work anywhere on the discharge side as long as there are no one way valves installed. It basically keeps the system pressure up, so any where in the system will work (The pressure will be the same through out the system), however, it is more effective as near as possible to the pump, so would normally before the system is tee'd off. With the 30753-series pumps, remember to set the pressure of the tank to 2psi below the cut in pressure, of the pressure switch..
Jon
