frenzy
The motor assembly is the most expensive to replace. I believe about £170? You are in the realms of throwing good money after bad. Have you done the obvious and seen if it can suck water out of a bucket next to the loo? Personally I think it would be very obvious if the motor was failing as the speed would be noticably slow. On mine, I didn't use the service kit. I changed both the impellors and chopper (although none looked as if they need to be changed so I've kept them for spares (after bleaching them!!!). The biggest difference was the wear plate (which I don't believe is in the service kit - item 23 on the exploded view?) and the shaft seal (items 29/30) behind the rubber impellor and the motor as this is a prime candidate to leak if you disturb the shaft. Its like a new unit now and is quite different to its post repair state. Mine is the 1090 variant for what its worth.
The service kit I got included the wear plate,impeller,shaft seal etc. I do no think there is anything else to replace. Yes I have tried the hose with a bucket and its drawing the water at a very weak rate. (Dribble ) Sometimes it increases but generally very poor.
If I fill the hose with water and blow it though and then place in a bucket of water it does draw well for a second or two.
