William_H
Being a compulsive puller apart of junk specifically in this case old computer power supplies I have found that they contain Schotky Diodes in a high powered pack. The specific one I found data for is rated at 30 amps and has a forward volt drop measured of .15 volts. This means that you could uuse it for isolating yet charging your second battery or for ensuring safety when using 1,2,both switches. Thi9s volt drop will detract form your charging voltage but obviously not as much as a silicon diode at .7 or more volts will.
The diodes come as a pair in one package unfortunately the cathode is common so you would need 2 packages. Connect the outside 2 anodes together and connect to the alternator out and the middle terminal to your service battery. Connect another package in the same way outer 2 terminals to your alternator out terminal or wire and inner terminal to your engine battery.
Of course the wiring of your system is never that simple so these diodes should be used as any other diode isolator.
The body of the diode pack has a metal surface which should be firmly bolted to a piece of aluminium which becomes a heat sink. You will need 2 pieces each at least 10cms by 10cms or similar area. If the diodes are bolted to the aluminium then the Al becomes electrically connected to the positive of each battery. You will need to isolate it from any thing at negative earth potential and fuses at the battery would add to the safety.
The other alternative is to bolt the diode to the aluminium with a thin mica or special plastic washer between the body and the Al. These washers are designed to conduct the heat but electricaly insulate. You may need also plastic insulating washer to insulate the attaching bolt. These insulators will come with the diode from the computer power supply. Check with a meter after tightening the bolt to ensure insulation. and use fuses.
the only tricky part is to identify the diodes about 1.5cm square 4mm thick with 3 wire legs. They have a symbol of 2 arrows pointing toward one another and the centre lead. There may only be one large one in each power supply. There will be 2 transistors in there that look similar but are no good to you. This is especially for those of us who love to recycle and go cheap. PM any questions olewill PS no I havn't tried it. Wouldn't have a motor on my boat so let me know if it works out well.
