jfm
Gludy I'm struggling here with your physics. Can you not see how utterly wrong your original statement is? ("It takes the same energy to turn ... a prop using an engine at say 500 rpm as it does to turn a loose prop at 500 rpm. So a dragged prop turning at X speed needs the same energy as driving one at X speed"). Nothing could be further from reality, you are miles off base with that statement. Agree?
Your "the free prop would turn much slower than the driven prop but would still use up the energy in spinning that was well in excess of just the frictional loss on the shaft" is not correct. What energy? The only energy beyond the friction is the foil drag of the prop blade. Nothing else. What you are saying implies that a glider wastes a load of its energy stores (being potential energy, due to gravity) in addition to overcoming the foil drag of its wings and the general fuselage friction. Well, no it doesn't
And no i dont agree at all "all else being equal lets say it takes X energy to drive a boat at 8 knots with two engines. Then (assuming the engines have the power) it would take more than 50 per cent of that energy to drive the same boat at 8 knots with one engine if one prop was left freewheeling"
First, you mean power not energy. But the answer is that, ignoring prop losses etc, it would take 100% of X power to drive the boat on one engine at 8 knots, just as it took X power to drive it on two engines at 8 knots. Indeed it would take X power to do 8 knots even with 100 engines. I think what you meant to say was if it takes X power at 8knots on 2 engines, then it would take say 95% or 105% of X on one engine, with the other dragging. Yes that could be true true, but it doesn't prove your theory at all. I'd say (ignoring the stall point) that it takes power of say 105% X with one engne running and the other windmilling, and 106%X if you apply the shaft brake ignoring engine inefficiency, but including prop drag. If you include engine waste, the answers could be say 94% windmill 95% braked
