30boat
N/A
Though they presumably come with keels, rudders, electric, engines, intact hulls and things like that.
Keels are optional...
What's a latent stress?
Latent stresses are stresses that have yet to manifest themselves. IE a given material or part can be severely stressed as a result of impact or other force beyond its design capability and not show any signs until it is stressed again. The resulting failure can be instantaneous and catastrophic.
I'm sorry, but that doesn't make any sense at all. A stress is an internal force; you seem to be describing damage, which is completely different.
Damage occurs because the given material or part is simply stressed beyond its physical limits, you seem to be suggesting that damage could not cause latent stresses because the force was external? That doesn't make any sense to me, Forces are absorbed and released at some later point (latent stress) resulting in structural failure, damage is the result but is often also the root cause,
Sorry, but I still haven't a clue what you mean by "latent stress". A stress is an internal force. It's either there, in some quantity, or it isn't.
Ok let's substitute the word stress for defect...it amounts to the same thing.Sorry, but I still haven't a clue what you mean by "latent stress". A stress is an internal force. It's either there, in some quantity, or it isn't.
I don't think you can induce latent stresses on a Bavaria by bashing it on the rocks.You can weaken the structure invisibly but that's not the same.If you were for example to twist the boat by force and then lock it in that shape by laminating over then you'd be inducing stresses.Ok let's substitute the word stress for defect...it amounts to the same thing.
But to further clarify, take a piece of material let's say extruded acrylic. Now the extrusion process is highly stressful ( as opposed to casting) and as a result the material is stressed and retains that stress. it copes because it is within it's design parameters, however if you drill it, cut it or machine process (damage or thump it) in anyway you stress it further, this may not have any apparent effect during the operation and the additional stresses may never show but on many occasions cracks will start to appear around drilled holes or cut apertures and these can occur a long time after the processing or impact damage occurred these are latent stress cracks, IE delayed as in.....latency.....you may not understand that or agree with it but it's a fact, it happens..... in all sorts of materials.
Stress can be nullified or reduced by annealing and this can completely remove internal stresses, you can't do that with a 42ft Bavaria! Maybe there is a marine structural engineer out there that can shed more light on this and answer my original question?
Delamination may be the term to use, it's latent to the extent that impacted areas may appear to look OK but will in fact be weakened. Delamination can be cut away and rebuilt. It will still be pretty strong overall and you'd have a hell of a job to weaken the boat to the extent of it being dangerously weak.
It probably could be repaired and be adequately safe, but the problem would be that it would be impossible to re-sell at a sensible price reflecting the work involved. Any surveyor would no doubt advise walking away, as there are loads of perfectly good versions of the same boat available on the market.
You learn something every day.I have never seen the term "latent stress" used.
This thread has become a pedants' discussion.
Either way i would have thought it would be worth more sold for parts.
