I have emailed Allen Bros. (I think Jon Neeves mentioned they have an Australian outlet in Sydney)Not sure if Allen do that size
Allen Blocks
I once needed some odd blocks for a dinghy.
I turned the sheaves out of acetal, with stainless bearings sold for skateboard wheels.
The sides of the blocks were a mixture of plastic and stainless sheet.
These days I would think about Carbon Fibre for the plates.
But 15mm rope implies strong engineering.
Looking at that mainsheet setup, I can’t see how you adjust boom to port/starboard to trim sail. Am I missing something, or are you happy to do without that adjustment?
I had half a metre of carbon cloth kicking around, and a pot of epoxy.I had a quick search for carbon fibre sheet to make the plates - maybe its a problem with Australia - but carbon fibre sheets are extortionate. If you had a true weight fetish and were top of you game building and sailing foiling Moths I'm sure if might be the answer - but it seems (from the 10 minutes I spent searching) only for those with bottomless pockets.
I'd stick with 316 stainless (or maybe 2205 Duplex stainless).
But, never say never - if its cheap in the UK - I'm interested
Jonathan
These two mainsheets are very different.
Assuming the blocks in the phot don't slide on the white/blue rope, this system won't provide much leach tension as soon as the boom is off the centre line.
It's a fine system, I have iessentially the same on a dinghy, but I have a 16:1 vang bending a carbon boom to do the leach tension.
The system in the sketch, if you move the boom off centre, you have 2 strands of the main mostly pulling down and 2 pulling to windward and down.
Again it's a fine system, great if you don't have a strong enough boom for the kicker to do all the leach tension up wind, and your rig is designed for the boom not to be so close to the centreline.
