Is there a tool that will......
NealB
19 Feb 2006
Burnham on Crouch
I need to cut an 8mm hole through about 1.5 inches of oak.
Trouble is, the hole needs to be right in the corner of a right angle between two pieces of oak, and parallel to one of the surfaces, so there's no room for a chuck or the body of a drill.
Thanks for any ideas.
flexible drive
a cheap flexible drive hex end, hex ended 8mm drill would be slw but possble better to pilot with a small drill first you migt have to grind the end of the 8mm to a hex shape
go with fireball's idea for ease if possible.....if not just have the drill type of your choice brazed / welded /sleeved onto an extending mandrel/bar by a local engineer
something purpose built, like this
Thanks for all the suggestions.......the flexible drive might work, though it will be working through a fairly tight radius.
Can't drill from the other side, and no room for an extended bit.
I'm intrigued by the 'red hot poker method'..........don't tell me......you get a poker, make it red hot and then use it to make the hole.......something like that? Bush engineering would be entirely acceptable.
"the hole needs to be right in the corner of a right angle between two pieces of oak"
The answer given by fireball is the only one that satisfies this requirement. If it is not possible to remove the structure to do this, then the OP needs to question whether the hole needs to be "and parallel to one of the surfaces" as it may be possible to drill in at a shallow angle using a bit held in a chuck. The chuck will need to be a small one and either an angle drive or flexible drive may provide this, or a small cordless drill could be used. The battery would need to be fully charged before starting to drill 1.5" of oak however!
