Is there a cheap LED replacement for cabin fluorescent tubes?
Burnham Bob
18 Jul 2009
Burnham on Crouch
I have a fluorescent fitting with two tubes in the main cabin of the boat. No problem to date with battery drain but is there a cheap way to replace with LEDs? Ebay offers lots of cheap LEDs for various uses - including replacing2,3 and 4 ft tubes, online swindleries charge an arm and a leg. Caravan shops are hardly any better.
Any recommendations? £16 seems to be about the cheapest for straight swap of the tube.
OldBawley
9 Aug 2010
Cruising Med
Had two Aqua signal fluorescent armatures above the galley, warm white fluo tubes unobtainable here in Greece.
Bought two meter of led strip ( Warm white ) and fitted them into the armatures. Fitted new old style switches. All the old electronics are still in place, cut the strip in three pieces, mounted with some copper wire onto a plastic bearer and reddy. Some soldering and presto, 45 very strong led´s under the original armature lens. Gain in light enormous, paid 10 €/ meter for the strip.
KAL
9 Feb 2006
River Dart
Boatlamps do a straight replacement, but it s about £25 I think. I bought one as an experiment and am v pleased with it. Lovely warm light. Still uses 5w though...
JumbleDuck
8 Aug 2013
SW Scotland
I was looking at these yesterday. Am I right in guessing that you have to remove all the electronic gubbins from the lamp holder, so the LED thingy gets a straight 12V?
KAL
9 Feb 2006
River Dart
Apparently it helps, but I've used it for a whole season now with no probs. I gather removing the 'ballast' from the light fitting will reduce the current needed, so I will get around to it sometime. Very happy with the quality and colour of light.
JumbleDuck
8 Aug 2013
SW Scotland
Ta.
concentrik
10 Jul 2008
Lidl, where else? I can recommend the LED silver slimline units they had on sale a couple of weeks ago - £10 each - as I have been using a number of them aboard for three years. They look good (In my opinion), the light is not too cool (for me) and they have an integrated touch-on touch-off power sensor. They have survived many months use so far (we routinely leave a couple on overnight when in a marina) and have shown no fear when encountering the DC from our mad alternator, which due to a faulty regulator was keen to share its 17v of goodness sporadically last year.
