Is that acceptable if idle speed dropped 20 rpm after oil changed?
Boater On Thames
5 Oct 2018
Just found my two Volvo TAMD61A engines both drop 20 rpm after changed the engine oil to SAE40 two days ago. The idel speed comparison:
Before:
Port 585
Starboard 615
After:
Port 565
Starboard 595
Was there a special reason for SAE 40?
15W/40 is more usual.
This
Thank you Scala. I was thinking to order the local brand VDS3 oil. Then I learned that their TBN usually around 9-10 only. It is better suit modern high speed engine with low sulphur fuel I think. And it might not good for my engines because I only use it almost always 600-1000 rpm only on the river and use very little hours. So I decided to use the old school SAE40 thick mineral oil instead. Then when comes to the coolant, I found there is no such product call anti corrosion additive for engine. Only found some general correction inhibitor for central heating system and commercial cooling system. I think it should be no different between engine metal or commercial metal or home metal. As long as the inhibitor is for all kinds of metal. I might be wrong, so that is why I am here to ask.
Lucas i think you are trying to fix a problem that doesn't exist, if your tickover has dropped now with that oil, what will it be like in winter @ 5 degrees ?. Just stick 15/40 in and forget about it.
Whats the thinking that leads to deviate from the 15W40 grade if that is the recommended oil for your engine?
At normal operating temprerature a straight 40 grade will be the same viscosity as a 15/40.
At cold/start up temperature it will be more viscous.
If the OP's engines were not at normal temperature, the increased drag of a more viscous oil would drop the RPM.
Old oil can be less viscous than spec. if it has had lots of use and contains contaminants, so even new 15/40 migh have the rev drop effect.
