Is my outboard 50-1 or 100-1 mix ?
richardhart90
New Member
2 Sep 2012
I have a Mariner 4hp 2 stoke outboard and wondered if any one could tell me the correct fuel mix
i have been using 100-1, but some people say use 50-1 !
I was told 50-1 at sea, and 100-1 on rivers !
Believe its 1984...
Serial no
4A M GE0 S 052076
Cheers
Rich
Believe its 1984...
Serial no
4A M GE0 S 052076
Cheers
Rich
I had one similar, but 5hp, and always ran it on 100-1. No problems, and the guy that bought it is still using it daily.
My impression talking to experienced outboard mechanics is that it is generally better in terms of engine health to run outboards rated at 100:1 at a richer oil mixture. Most seem convinced 50:1 is the best option, unless the operating conditions are unusual.
If you do run at 100:1 make sure it's the higest spec outboard oil and a reasonably fresh mix.
Quite a few manufacturers sold the same motor for leisure and commercial use.
They rated the leisure ones at 100:1 but the commercial versions at 50:1
I certainly wouldn't run at 100:1. Some sources suggest a halfway house 75:1.
If in doubt use 50:1 . Its the safe mix for most engines of this age.
You might get away with 100:1 for light use but if you do be sure to fog it when laying up
I think you are right about the year but the serial number is 6E0 not GE0
You should be able to find an owners manual in the Brunswick Marine Download center http://download.brunswick-marine.com/download/main;jsessionid=105vjo07c1lcd?type=corp although its not always easy to find the right one
My outboard motor handbook said to run in with 50:1 and then to use 100:1.
But my portable generator requires 50:1 so, rather than have two petrol cans, I just use 50:1 for both engines.
The outboard doesn't seem to mind. It always starts easily and doesn't produce any noticeable smoke.
