paultallett
On our way to Cowes yesterday I started to get irratic readings from my leg trim gauge!! (Mercruiser Mag 350, Bravo 3 leg & Faria trim gauge) It used to be rock steady and move in perfect sync with the leg. On Sunday as I would trim up from the '0' postion the gauge would show that I was triming down.....then suddenly shoot to a '+' reading......then flicker about a little until it settled in a completely different reading......and so the game continued!!!!
Once at Cowes, I checked the the leg was doing as it supposed to, I cleaned the wire conntacts coming from the transom plate along with all the contacts at the back of the gauge but it has made no difference!!!
Does that sound like a gauge fault or is it the sender unit on the leg?? I can replace the gauge easy enough but can't get at the sender unit with the boat in the water.............Don't know where to start.... /forums/images/graemlins/blush.gif
Regards,
Paul.
Regards,
Paul.
