steve yates
or is it too cold? I'm wondering if itys a bit like painting, where the temp needs to be reasonable to start the work? Or does it just take longer to go off the colder it is?
I have to guess battens are always wood?
I'd never use polyester to bond wood, as polyester does not "bond" wood.
Yeah i was starting to worry as all the jobs ive done have been ply and poly...with good preparation i assumed it would be fine.Good heavens, i'm deeply in the sheet then, as is almost every other GRP boat owner in the galaxy, by bulkheads, floors etc, etc, etc are all bonded in with polyester.
There are cheaper alternatives to gorilla glue as well if you buy from CFS fiberglass online or look around.Thanks all, very useful.
Kieth, I'll pass on the cobalt stuff, I'd just blow up the boat
I'll prob go with atols suggestion of gorilla glue instead. Doesn't need glossing over, I'm just screwing some hardboard panels onto it.
40%? Are you sure? Max 2% in my book.I would recommend that you leave it until spring unless its an emergency!
I fibreglassed some gussets from boat deck to transom in late October with poly resin and 40% catalyst. Outside ambient temp was 8°C and took 2 days to fully cure and thats with me keeping it warm with the missus hairdryer. Then the flowcoat on top was a nightmare to cure too.
Yes i do apologise i meant to say 4%!!!40%? Are you sure? Max 2% in my book.
A chap here who spent his life making mouldings had a chart of ambient temp on the wall. He adjusted the accelerator, not the catalyst. As above do not mix neat accelerant and catalyst.
Hey there, is this through direct experience? I've wondered & decided against pu adhesive bonding wood to fiber glass. I suppose if the fg is v rough it might fill small rugosities and so adhere that way? Be really interested to know how it goes, you can be the avalanche poodle Steveif you need to get battons in place you can use an expanded polyeurathane glue ,the damper the better! Gorilla Glue 250ml
Then fillet and glass over when the weather gets a bit warmer.
west system with a fast hardner should be okay down to about 8 degC
I built a track orientated car, a Dax Rush where the front mudgaurds are bonded to steel rails with PU. I was a bit dubious as they take a lot of strain but ther bond is probably stronger than the grp.Know I’m like a broken record when it comes to PU adhesives on here - but why not simply use a builders polyurethane adhesive in a tube? Cures through humidity anyway and cold only slows it slightly. Costs a fiver for 300ml. Can he had around the corner (toolstationt/screwfix). And comes off with a scraper and maybe a bit of heat if it ever needs to (and over the life of a boat, it probably will).
used it for the initial fit for all the batons,pads and bulkheads on my catamaran before filleting and glassing in with epoxy, you do need to remove wax before and after sanding FG ,but sticks as good as PU paint,and as a gap filler it avoids hard spots on the hull from bulkheadsHey there, is this through direct experience? I've wondered & decided against pu adhesive bonding wood to fiber glass. I suppose if the fg is v rough it might fill small rugosities and so adhere that way? Be really interested to know how it goes, you can be the avalanche poodle Steve![]()
