trouville
N/A
Last year i posted the same problem, I had run out of diesel got the engin going ran out again then a third time but then there was no diesel left at all.Tied up i blead the system (filled the tank)and started the engin.
Since then ive had a blacksmith banging his hammer on his anvil.Before that he makes it hard to start.I have to heat for 30 seconds press the diesel squert then start,mayby!!mostly another 30 second heat then quick start spayed in the air intake and with luck its starts??The blacksmith then hammers away for the best part of 60 seconds.
The glow plugs work becouse when i heat after spaying the quick start theres an explosion!
Once going she ok providing i use the engine every few days,that is the engine will start eventually without quick start spray but the blacksmiths their hammering.
Before running out this Ford 3 cylinder engin from 1960 was faltless!20 seconds to heat the glow plugs then start lots of smoke as she walmed up then very little always sounded sweet and smooth.Always started first time, errrr errrr errr errr whoomm brum brum brum!
Ive pumped with the fule lift pump had someone pumping while i bled blead while the engines running bled while running fast and slow bled again without engine running. But always the blacksmiths there.
Do i need a new injection pump??I dont want to change the engine cos its better than the new ones!!Apart from the blacksmith??
What can i do? Put my fingers in my ears?Turn up my MP3 player???
HELP!
/forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
HELP!
