zaragozo
Active Member
I have a Yanmar 4JHE-TBE in my boat which ran with perfect oil pressure (1-1,5 kp/cm2) before being serviced by a 'professional' marine engineering company. I provided the exact amount of new oil but they said they didn't need to use it all. I suggested that they didn't get all of the old out. They said they got out as much as the could. In the event I now get up to 4.5 kp/cm2 - well over the normal reading. They said it might be the oil pressure sensor that's gone wrong. The dipstick showed that the oil reservoir had been well overfilled and now after about another 150 nm of use it's still above the max level by a couple of cm.
I'm thinking maybe I should siphon off the excess? Would this lower the pressure? I've not had any other problems with this engine - it's a 2003 and has only done 650 hours. The operating temperature is normal, I can't see any leaks and am now getting a little paranoid as I am due on a longish trip shortly and wouldn't want the engine to split open or whatever.
I'd welcome any suggestions. The company which did the service had agreed to check the oil pressure with a gauge but haven't managed to get one yet - after 3 months...
